I'm about to pull the trigger on some 32x11.5x15 km2's.
I'm looking at black rock aluminium and pro-comp rims. What kind of offset am I looking for? Some have -19mm and some have -12mm does it matter what I chose?
Jeeper
How wide are the wheels? Offset is just mm instead of inches off centerline of the wheel, so if you know the width then half the width is center, and 12mm is about .5", 19mm is about .75". So they will be that far from center.
Jeeper
Well then, 3.5-3.25" bs is what that should equate to, if my calculations are correct. It really won't make that much difference....
Jeeper
ok, well. Math isn't my best subject :) They'll be fine.
