:welcome: to the Forum..:wavey:
^^^These charts will help you!!!
There are basically three things to consider. What size wheels do you want to run, 15, 16, 17, or 18's, with the correct bolt pattern. How wide of a wheel do you need for your tire size. And finally Back Spacing, how far out do you want to increase your wheel stance. Back Spacing is used for two reasons, number one the most important is for proper clearance and secondly for appearance.
Our Supporting Vendors, are very good and knowledgeable in helping members select the correct fit for your Wrangler!
