How much would a ring connector have cost for a primary ground?
I don't think it was the cost.
What I hear most about shoddy repairs is "I was in a hurry".
Once they have the vehicle back running, they forget about repairing the shoddy work correctly (until it fails again, then they call the vehicle a piece of junk).
Most of us have had to repair PO's shoddy repairs. Most often it's electrical.
Good Luck, L.M.
Good Luck, L.M.
Ain't that the truth!
If that's the first thing you've found, Get yourself a soldering kit, extra connectors and soldering supplies to have on hand so you don't have to do the, as Luckymac hinted, " I was in a hurry." repair. I have found that most electrical repairs were done consistently bad or consistently right.
Reactions: 9278 YJ
If that's the first thing you've found....
I’m working my way through some basics. I have a steep learning curve on the engine, but I’m pretty good with 12V, so I’m putting in a number of solder butt connectors replacing sound and other connections I don’t like. But PO but a 78 304 V8 in this 92 YJ, and didn’t clean up the wiring. So that’s my mountain...
Get the wiring diagrams from the FSM to help you decipher what's what.
Look for the link in Got it at Last post above for FSM's
