1 - 11 of 11 Posts
I have a 2001 Wrangler w/ 6.0 automatic trans.
Ever since I've owned it when I do oil change or take it for a quicky, if 6 qts are put in (which is what it calls for) it is overfilled on the dipstick.
When I do it or take it to the guy I would normally use, we use about 5.5 qts and it is on +/- full on the dipstick. He's a certified mechanic and he has no idea why it would do that.
I wonder if it is the dipstick - if that's the case then I'm always low...
Anyone else have this problem?
i have a 02 tj and it take 5, i know my user name says 03 but i messed up and i don't know how to change it
I add 5.5 qts (5 oil and .5 zddp additive)
The volume of oil that a particular engine will "hold" is totally and completely irrelevant.
"Why, shazamm, Goober. I done got 10 quarts in this thang, and it ain't even filled up yet!!!"
I think he meant the cylinders.. not the size.
I see…exactly 6.0 cylinders. No more, no less.
Jeeper
Regardless of the what the dipstick is showing, the 4.0L engine holds 6 quarts.
I have 2 Jeeps,both 4.0 & 6 qts fills them every time.I dont even ck it when Im done.
I always run 6 US quarts with a Mopar or Balwin filter and they are big, OEM size filters and hold quite a bit of oil. I don't pay much attention to the dipstick unless it's reading lower than full.
Maybe it's rounded to 2 significant digits because no one wants to write 6.000327 cylinders.
1 - 11 of 11 Posts
