The owner's manual from my Jeep Wrangler 2004 2.4 L 4 cyl. states the oil capicity is 4 quarts, but it takes 5 to fill it up. What is the correct amount?
5 quarts you sure the manual says 4 qts? mine says 5
you might want to post this is the TJ section you will get much more responses :)
Mine takes 5 with the filter change.
I went ahead and put in the 5 qts. which brougt it up to the full mark. The owners manual, which I purchased on ebay, on page 253 shows the 2.4 L engine taking 4 qts. with filter. The 2004 owners manual on line in a pdf file states the 2.4 L engine should take 5 qts. with filter.
Thanks
mine takes 5 quarts to bring it to the full line
My FSM shows 4 also.
