oil has been recently changed as i just purchased it(2007 model) a month ago-now how do shut it off!! ie-the buzzer!!:banghead:
Here is the "how to" out of the 2013 manual, I have no idea if it is the same or not.
Turn the ignition switch to the ON/RUN position (do not
start the engine).
Fully depress the accelerator pedal slowly three times
within 10 seconds.
Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
There's a buzzer?:eek: Never heard it in 5+ years!
Maybe you can't hear. I told the doctor my wife couldn't hear well anymore . He said to stand behind her 15 feet and ask her what was for dinner. If she didn't answer move up to 10 feet and ask again. Repeat again at five feet if she didn't answer at 10 feet. Well, at five feet she said " for the third time it's steak".
Dear Bad Ole Ross-Thank you so much!! It worked-oil change buzzer is off!! I could not find that info in my manual!! Appreciate your "real"" help not bs!!
You're welcome, glad I could help!
