I just changed my oil in my '13 I drained all of oil and put plug back in. Changed filter then put 6qts of mobile 1. Question is after I put six quarts in I started the engine and let it idle for 30 seconds.shut off the engine When I checked dip stick it was just about 1/8 in on end of dipstick. Is this right or should it be about halfway up on the dipstick gauge. I just don't want to run her with not enough oil.
Did you wait a few minutes to check the oil after shutting down? It takes several minutes to drain back down. When I change mine and add the six quarts it comes right up to the full line after waiting five minutes. Good luck.
