I got an oil change around 400 miles and 2 weeks ago. My 2012 Unlimited says "Oil Change Required" on the dash whenever I turn the car on. Any ideas? I've been late on oil changes too and have never had this happen before
Could be they did not reset the oil change reminder when they changed the oil.
I found this link:
Resetting the Oil Change Monitor - 2012 Jeep Wrangler Long-Term Road Test
Step 1: If you're not already familiar with the process, open up that owner's manual.
Step 2: Turn the ignition switch to the on/run position but do not start the engine.
Step 3: Fully depress the accelerator pedal slowly 3 times within 10 seconds.
Step 4: Turn the ignition switch back to the off/lock position.
