1 - 1 of 1 Posts
I have developed an oil leak on my 2014 JK. I only observe the leak either while moving up a high incline or immediately afterward. I have read that the oil cool leak can pool in the valley and then dump out when on an incline but that doesn't seem to be what's going on. I have not seen my oil volume drop as all outside of this instance. A friend was thinking that it could be the vacuum lines as the back of the engine but we couldn't find any that were clearly loose.
I have also found some mention of valve cover leaks on the 3.8 and also on the JL. Is this a common issue with the 3.6 JK?
1 - 1 of 1 Posts
