Usually happens once per day my oil pressure gauge will drop to zero and check gauges light comes on but it only lasts 2 seconds and returns to normal. Thoughts?
Sending unit going bad. Easy to replace.
I guess I should ask first, when does it happen? Going down the road, coming to a stop, only when the engine is warm?
Mine used to do it only after Hwy driving than coming to a stop. So, I replaced it. My new one only lasted 9 months. So, I'm trying to decide where I want to put a mechanical gauge.
It happens when i'm stopping except for one time it happened for a split second while just normaly driving down the road. Thanks!
Knows a couple things...
Replace the oil pressure sender & get it from the dealer. Senders purchased from cheap parts stores like Autozone are typically poor quality, unreliable, and not worth installing. My son's oil pressure sender failed & it took buying 3 senders on a Sunday when the dealer was closed to finally get an oil pressure sender that worked properly. One of them even read backwards... high pressure at idle & the pressure dropped when the engine was revved. That's some quality right there. :p
I had this problem, granted it wasn't in my jeep, but...what my problem was, was I had a slow oil leak. And ot would get loe on oil and the light would come on when coming to a stop. Then it would go away when I did stop or I took off again.
So if there's no oil leak and the oil level is good then look ↑ or ↓ for better answers.
Good luck
I bought a sender from the dealership last Sept. and it worked perfectly until 2 weeks ago and it started acting up again. The ones from the parts box stores lasted only a couple days though.
I got a sender from the dealership that lasted 3 days and then went bonkers. They replaced it and all has been well for about a month so far. Bound to have a bad one now and then I guess. FWIW: the factory units are made in Mexico.
