Hi All- I'm new here so I appreciate your help in advance.
When I first fire the jeep up cold (YJ 2.5) I get 40ish PSI on the oil pressure at idle. After she warms up the gauge pegs to 0 at stoplights and maybe 20 psi or so at speed. I would think if I had 0 oil pressure I'd have a pretty serious knock. The motor doesn't sound off or anything and it seems to pull through the gears just fine.
It's an aftermarket oil pressure gauge. I think it might be a mechanical gauge (picture attached but I'm not 100% sure at all). Is this oil pressure thing normal for these jeeps?
I have no idea what weight oil is in it. Filter is a microgard.
Welcome to the Forum nkd9,
I suggest that you change your oil and filter. I use regular 10W-30 or 10W-40, depending on how I feel when I'm buying my oil.
Once you know what oil you have, post again.
I'd also consider buying a quality oil pressure gauge if you're unsure about the one you have now.
Let us know what happens once you change your oil.
Good Luck, L.M.
Mine does not quite go to 0, but I have the same situation. It’s near 20PSI at 45 mph, but at a stoplight is running about 5. If you use the 10PSI for every 1000 RPM, I’m close.
I did change the sending unit, as mine was having the exact same situation as you.
At some point, I’ll put a quality gauge on it. It doesn’t rattle, and the oil stays nice and clean, so I’m not worried.
Get a quality filter like a Wix, 3 quarts of high mileage 10a40, and one quart of Lucas oil treatment. You will most likely see an immediate improvement.
When was the oil last changed? Did you verify the oil pressure with a trusted mechanical oil pressure gauge? That would be the first thing I would do if I suspected a problem with oil pressure after making sure the oil level was full. I would not throw anything like Lucas Oil Stabilizer in the sump. If you're running a 5W or 10W30 try a 5W or 10W40 and a Fram Ultra filter if the mechanical gauge gives the same readings you are getting now. If that doesn't work you will have to dig in further.
Ok. So I changed the oil. 10-40 with Lucas and a Napa gold filter. My dash gauge is mechanical, now I’m maybe getting 5 psi or so at stop lights. I read somewhere to bleed the mechanical gauge and I tried that too. Any ideas? Try a different gauge?
