I have a 2008 Sahara with a little over 50k miles. I am losing oil, but I can see no leaks. Valve guides or seals? Or? Suggestions appreciated!
Yup, You just have to try different weights and brands of oils until you find one that works the best for you... I settled on Castrol 10W-30 Extended milage vehicle oil (Green Jug).
Important thing is to watch the dip stick ...and pack a quart or two with ya....."BH"
It could be a lot of things, including problems with the valves, rings, or a leak which you ruled out. The 3.8L has a reputation for being an oil burner there are a few things you can try to reduce oil consumption. Moving up a grade to a 30 grade oil might help. You can check the valve seals. It could also be sticking rings. I would consider pulling the spark plugs and do a piston soak. I'd do that right before your next oil change. If the rings are sticking it might help. There's a lot of information on the WWW. on how to do a piston soak and what to use. I'd read up on it if you're interested. Good luck.
Thanks everyone! I really appreciate all the suggestions. It gives me a good start to solving the problem!
