Offset to what??? Do you mean do they require wheel spacers with 31's? Since offset is built into wheels, the question doesn't really make a lot of sense.OME Heavy Load 2" lift scheduled to be installed professionally in early April. Apparently, I'm not the only person who spends his tax refund on a lift kit....who'da thunk it?!
First time Jeep owner. '05 Wrangler X with 38k miles. Pretty much bone-stock, except for the aftermarket bungee cords on the front bumper and nifty new grab handles.
Plan on keeping the stock rims, while adding 31" all-terrain tires (still undecided). Mechanic was asking if the stock rims require any offset?? I wasn't aware this could be an issue with suspension lifts.
Thanks all.
31x10.50's will work fine on your stock rims. Worst case, if there is minor rubbing at full lock, just put a couple of washers behind each steering stop
