1 - 20 of 28 Posts
Thought I would start this build process. Should be a little different than most. I am 66 at the start of this post. I have had numerous Jeeps over the years. Too many to count. A Grand Wagoneer, the big two door Wagoneer with the eagle on the hood, three Renegades, and a 07 JK unlimited. Also had the Grand Cherokee with the factory 360 with the factory hood vents to help the heat escape.
My grandson got a 08 JK for his 17th birthday. Also a few of my old high school buddies purchased Wranglers to play with. So, I had to get another one. I wanted a Wrangler that I could write a check for and not have a payment. I like the locking differentials but did not want the automatic sway bar unlock feature nor the rock rails. Rather have the side steps. I looked for about a month and came up with a one owner low mileage black Dragon Edition. I know there was a lot of bad publicity about this edition. But, it pushed all the buttons for me. It has the manual transmission, factory navigation radio with back up camera and just about every other option that was available in the Sahara build sheet. It will go off road. Just not mud bogging or rock climbing.
Attached is a picture of the JK while I was working on removing the Dragon decal.
Welcome!
What are your plans?
I am in to Radio and Communication. I am installing a Dual Band VHF - UHF radio that I will post. I am also installing a HF rig that I will post. A Banks intake and exhaust. Winch Bumper and winch with synthetic rope. 2017 Rubicon Headlight swap. Just for a start
Before you purchase the intake and exhaust, I would encourage you to do some research.
Banks makes some great products, I have some of their products in my Ford 7.3, I have heard mixed reviews about installing any air intake or exhaust on the 3.6
Dragon was a package based on 2014 Sahara’s.
There are a few of them out there, but I think most of them have had their dragon stickers removed.
Discussion Starter #9
I thought my back up camera was a factory option, but in running some wire for my radios, I saw that it was added on. Here is the location of the Camera at the Tag. It does a very good job and has a full field of view.
Discussion Starter #10
Got my Intake and Exhaust in from Banks. Attached is a picture of my completed Intake. Straight forward easy install.
Discussion Starter #11
Ordered the Talkie / Microphone holder from JeepUniq. Easy install. Sturdy holder. I recommend this mount for anyone wanting a good location for a holder with no drilling.
Discussion Starter #12
OK, last build post for today. Attached is a picture of my Baofeng BF-F8HP Talkie in the JeepUniq mount. The Baofeng Talkies have been cover numerous times, so no need to go into detail about them. Bottom line. They are very inexpensive to purchase. About $30 a piece straight from China. The BF-F8HP is rated at 8 watts, but will do almost six watts on a test bench. Pretty good quality and a great investment for the money. I have two on board and if one gets damaged, just throw away. The batteries hold a good charge. Bottom line they just work. These are keyboard programmable. So be careful what you put in these for a transmit channel. Most frequencies are narrow band while some are still wide band. If you don't understand that, you need to have someone program it for you. As a side note, these will pick up FM broadcast radio.
Discussion Starter #13
OK, here is a post showing the Dual Band VHF / UHF Radio install. The radio is a Icom ID-5100A. This is a true dual band radio with plenty of alpha numeric labeling so that you can keep up with the channel programmed in and not have to rely on remembering what the frequency relates to. Also to complete the install, there is a Rugged Radios Side antenna mount. $45. A Tram Dual Band antenna whip. $15.00 a black Phone firm mount off Ebay. $10.00 I also bought a piece of rubber / neoprene gasket sheet to make a gasket between the antenna mount and the windshield frame.
The first item is mounting the antenna bracket. JK13.jpg I took the bracket and traced onto the rubber gasket to cut a pattern out. I used the original screws from the windshield. The supplied screws were not correct for the application. Take the plastic washers off the original screws and use a brush or scrap to remove the paint coating from the back side of the screw. JK14.jpg Now take something and scrape the paint from around the holes where the screw holes are on the new bracket. jk15.jpg The purpose of this is to get a good ground to the bracket when the mount is attached. Once attached, make sure there is continuity to the frame. Now you can mount the antenna mount to the bracket and Antenna. JK13.jpg JK12.jpg Run the coax to the inside.
Discussion Starter #14
OK, we'll mount the radio inside.
The radio body was mounted under the seat.
I used the Black Phone Firm mount from Ebay to attache the head of the radio to the dash just above the main car radio. Use a little bit of double sided tape to hold the bracket in place.
OK, here is the finished product.
A neat install. No holes drilled into the Jeep. This Radio has a Bluetooth option which I installed to allow you to use a Bluetooth Headset with the radio to hear and talk.
The Black Phone mount works perfect to mount a I-Pad tablet ect. in the same location if you did not want to use for a radio mount. Just order two of the mounts to hold a tablet. Mount the iPad for off road navigation and a dash mounted trail camera.
Discussion Starter #15
OK, this post and maybe one more will cover the install of my HF Radio. The Radio is the Kenwood TS-480HX. This is the 200 watt SSB radio without the antenna tuner as I wanted the most power available and no need for an internal antenna tuner as the turbo tuner and little Tarheel would take care of that. Also this radio has the Remote head. The radio covers from 6 meters through 160 meters. I also am using the Little Tarheel II antenna controlled by a turbo tuner II.
I purchased the Rugged Ridge 11503.96 Jeep Wrangler CB Radio/Antenna Mount Kit 07-18 for the Antenna mount and Control Head Mount.
The antenna mount goes into the typical location at the rear tire. I attached a small piece of Stainless plate to make the mount work with the Little Tarheel antenna.
Next mount the Antenna.
Finally to make sure there is a good RF ground, attach a grounding strap from the rear door to the body.
With this antenna set up, the antenna loading coil will move up and down via an internal motor to tune the antenna to the frequency selected by the radio.
Screwdriver antenna on the back is a good idea, no need for a tuner and it gets the feedpoint up closer to the roofline. Have you had any problems with RF getting into the vehicle electrical system?
Discussion Starter #17
This post covers the install of the TS-480 Radio.
As a side note, I see a lot of post regarding CB vs Ham Radio vs VHF vs UHF. Each has it's advantages and disadvantages. VHF and UHF is good for short range and clear communication mostly free from motor noise and static. But there are very few frequencies available above a couple of watts of power without a licence. CB works good and is limited to 4 watts legally. If you get stuck in the outback and have no cell phone service, or no repeater service on V or U, the chances of a contact on CB will be very slim also. On the other hand a true HF rig will almost always be able to get in touch with someone. Yes, HF requires a Ham Licence. But now a days it is getting easier and easier to obtain one.
Now back to the post.
I took the CB mount portion of the Rugged ridge mount and modified so to be able to place the remote head above the rear view mirror. Accessible and up and out of the way.
Next I mounted the body of the radio and the Turbo Tuner right behind the rear right side passenger seat.
Now, here is the finished set up with the HF rig at top , VHF / UHF rig just above the factory Navigation Radio.
Discussion Starter #18
No issues on RF into the Jeeps electrical system. I am using a lot of bead chokes. Try to use proper grounding. The radio just produces 10 watts while the tuning is going on. So far very pleased.
How did you get a good RF ground to the chassis from the spare tire mount?
(edit: nevermind, just noticed the picture above :facepalm: )
Discussion Starter #20
I scrapped some paint from the bolt holes on the antenna mount. Used stainless bolts to attach the mount to the spare tire mount. I then made sure there was good continuity from the antenna mount to the steel of the rear hatch door. As one of the pics show, I attached a flat braid wire from the door to one of the existing floor attachment rings.
1 - 20 of 28 Posts
