On bord air or winch
2691 36
I'm getting ready to make a big purchase for my jeep and want some opinions I want an on board air system and I want a winch but can't decide which one I want to get first what do you all think
1 - 20 of 37 Posts
H2_recoveryteam said:
Get a cheap air comp that hooks to the batt. And a winch.
Well I guess I could do that . Any recommendations on a good cheap air comp ?
I looked at one of those at my local parts houses but wasn't sure about it I'll check in to it more thank you
· Premium Member
I'd go with the winch first. While having on-board air is nice, having a winch will ultimately save the day when you inevitably get stuck.
I think winch also, its a big purchase and if your ready to drop the $$$ I'd do it all in one swoop. winch , plate, electrical setup
But then again I am a bargain shopper, if OBA's have better rebates than winches right now, I'd chase the sales and rebates.
I'd say it depends on your wheeling needs. I go wheeling in places where I can get stuck, even though I haven't. Also, do your friends have winches and tow straps?
Onboard air you can use all the time. Viair makes a nice compressor.
Are you going to eventually get ARB lockers? Then buy an ARB compressor.
These are all questions you need to ask yourself.
Winch! You can always drive home with low air AFTER you winch out. That said, I love my OBA. I bought a winch one year and the OBA the next. I probably use my OBA more than the winch but I've never "needed" the OBA and there have been many times that my winch saved the day for either myself or a friend who had chose different accessories over a winch. :)
Agree with what has been stated above. You can do both. I can get you a powerplant for much less than what Amazon advertises... Or you can go with a budget setup. Engo for $289 and a *really* nice (much better than the Q Industries setup) portable air source with 5.65 CFM for $130. Combined, that's less than you'd pay for most OBA setups or a winch alone.
That said, VIAIR makes an incredible OBA setup, which is what I run on my rig. That is a convenience though. A winch is the more needed of the two.
Discussion Starter · #14 ·
I looked in to a power plant but damn those are big$$$ one of them would me the trick set up I think
what do you have that puts out 5.65 CFM for $130?? I am really interested in that.
Discussion Starter · #16 ·
Super winch S4500<- 4500lb winch ?
I think you need to be in the 8000-9500# range for a standard jeep winch, when you are stuck you're pulling more than the jeep weight to over come the force holding you.
Superwinch S4500 is an ATV winch
Discussion Starter · #18 ·
I figured it was too light thanks ( damn thought I had a solution ) a guy I work with has it was hoping it was bigger than it is
winch prices will scare you to death...that's one big chuck of change!
Discussion Starter · #20 ·
Yes they have that's why I have been looking for a good used one
1 - 20 of 37 Posts
