on road stability after lift??
938 4
I installed a 2.5 OME lift, soft springs, and a 1.5 BL on my 2000 TJ. Ever since the lift, the jeep like to get a little dancy when going over rough bumps. any cure for this? all components are tight. like, if i hit some washboard on a dirt road it will dance all over the place. didnt do that on stock suspension.
installed adjustable track bars, front and rear links, aligned it myself. i am running 33's now. something had to have changed. i need to measure all the dimensions to make sure the axles are square with the jeep and each other.
what track bars? how much bumpstop extension front and rear? what's caster, toe in and camber?
