Just got the specs for my new x...I have read alot of arguements on different forums about not being able to run larger tires unless you have a dana 44. so with these specs can I safely run 16 inch wheels with 31's on em??
*P5 Cloth High-Back Bucket Seats
-DV Dark Slate Gray
ADCS Convenience Group
APAS Monotone Paint
A81P 4.0L Eng (ERH)/4Spd A/T 42RLE (DG6)
BAUS 117 Amp Alternator
BC2S 600 Amp Maintenance Free Battery
BGAS Power Front Disc/Rear Drum Brakes
CADS High Back Bucket Seats
CAFS Easy Access Driver Seat
CAGP Easy Access Passenger Seat
CDBS Reclining Front Seats
CFMS Rear Folding Seat
CGWS Next Generation Front Air Bags**
CKES Front Seat Area Carpet
CKFS Rear Seat/Wheelhouse/Cargo Carpet
CKTS Cargo Tie Down Loops
CLC Front Floor Mats
CLMS Sport Bar w/Full Padding
CUFP Full Length Floor Console
DGBS All 4-Speed Automatic Transmissions
DG6 4-Spd. Automatic 42RLE Transmission
DHAP Lock-Up Torque Converter
DHNS Command-Trac Part Time 4WD System
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Axle Ratio
DRJS Dana M35/194MM Rear Axle
ERH 4.0L Power Tech I-6 Engine
GBBS Tinted Windshield Glass
GCBP Front Door Tinted Glass
GCD Deep Tint Sunscreen Windows
GCF Full Metal Doors w/Roll-up Windows
GNAS Rear View Day/Night Mirror
GTVS Swing-Away Mirrors
HAA Air Conditioning
JAYS Instrument Cluster w/Tach
JCDS 100 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJFS Single Low Note Horn
JJJS 12V Auxiliary Power Outlet
JKAS Locking Glove Box
KDRS STRIPE/BADGE/MOLDING/COLOR
KWRS STRIPE/BADGE/MOLDING/COLOR
KXRS STRIPE/BADGE/MOLDING/COLOR
K3XS STRIPE/BADGE/MOLDING/COLOR
LBBP Courtesy Lamps
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPSS CHMSL Lamp
MBAS Painted Front Bumper
MB5S Black Rear Bumper
MCKS Black Bumper End Caps
MFPS Chrome Headlamp Bezels
MFRS Black Front Frame Overlay
MFTS Body Color Grille
MT2S Trail Rated Badge
NAS 50 State Emissions
NBGP Federal Tier 2, Bin 9A Emissions
NBKS EVAP Control System
NF1S 19 Gallon Fuel Tank
NZDP Next Generation Engine Controller
PSB Bright Silver Metallic Clear Coat
QSBS Bright Silver Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RBKS AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCAS Steering Wheel
SDAS Normal Duty Suspension
SHAS Front Stabilizer Bar
SHCP Front and Rear Stabilizer Bars
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TMSS P215/75R15 RBL Wrangler AT Tires
TZAP Goodyear Brand Tires
VJX Black Soft Top
WJ5S 15X7.0 Full-Face Steel Wheels
WKBP Matching Spare Wheel
WLYC All Steel Wheels
XCYS Upgraded OBD-II Connectors
XEES Fuel Tank Skid Plate Shield
XEFS Transfer Case Skid Plate Shield
XJFS Tethered Fuel Filler Cap
XPFS Protective Coating and Remover
YAAS Build To U S Market Specifications
YHUA 3.2 Additional Gallons of Gas
ZAVP Spring - Left Rear
ZBGP Spring - Left Front
ZNVP Spring - Right Rear
ZPGP Spring - Right Front
Z5BS Payload Rating - 1800#
1AAS U.S. Dealer Retail
142S Zone 42-Detroit
2TXA Customer Preferred Package 2TX
24X Customer Preferred Package 24X
4SB Front of Line Tracking
4VL In-System-Vehilce-Locate Tracking
5ISS TJ-Vehicle Family
5I4S Four Wheel Drive (4WD)/(4X4)
5I8S Left Hand Drive (LHD)
5N9 Dealer Inventory Management Order
5ZBS Price Class H
5ZHS No Cargo Box
593S Short Wheel Base (SWB)
594S Vehicle Order Tracking
6USS Label - U.S. Specifications
636S Ohio State Code
936S Ohio State Code
-DV Dark Slate Gray
APAS Monotone Paint
LBBP Courtesy Lamps
LDAP Underhood Lamp
LPSS CHMSL Lamp
RCDS 4 Speakers
SCAS Steering Wheel
VJX Black Soft Top
5ZBS Price Class H
5ZHS No Cargo Box
