What problems if you change oil and put a little too much in your TJ?
How much too much? The problem with too much is when the level is so high that it come in contact with the crank shaft and gets frothed up. The imbedded air can cause the pump to loose pressure.
how much too much? The problem with too much is when the level is so high that it come in contact with the crank shaft and gets frothed up. The imbedded air can cause the pump to loose pressure.
x2
Modern cars are supposed to be able to handle having one quart to much or too little in the engine, so unless you have more than a quart extra you should be fine
