Keep Stock Running Boards, or Rip 'Em Off?
1 - 20 of 22 Posts
None is better.
If you want the side to look more finished, get some diamond plate, like a Rubi, or rock rails. I like mine as they have a tube, but they sit higher than the body.
I just think the stock running boards look so dorky...
Around here, the OEM plastic side steps are more accurately known as rock magnets. If you still have them on your Jeep, you are screaming out to all the world, "look at me--I never drive this thing in challenging terrain!!!"
Ditch 'em.
Im the only vote for "keep em", only because my significant other likes to use them to get in.
If you dont have to worry about passengers, ditch em or go for sliders.
Mine are still on. Voted to take them off.
The wife says she likes them. They will be coming off when she isn't looking.
Never get stepped on getting on or out of the Jeep.
They make a mess of your pant legs when the weather is bad.
Right now, it's the only means of getting the wife in and out. I'll be purchasing the Drop Kick Slyders very soon though.
Same here, only have them on so that my wife can get in and out easier. I will most likely be removing them as well.
take em off for sure...
if you're keeping them for the girl to get in, she'll figure out another way. My girl is 5'3 and gets in just fine. My jeep from ground to the lip to get in is appx 35" as well. The first few times are awkward to get in but they develop a technique to get in.
Take em off
Pull them off and see if you like it. You can always put them right back on. Do you use them as a step? I don't think they are that dorky but I took mine off because I never actually used them, I found myself stepping over them instead of using them. They also collect a lot of dirt and debris.
I took mine off because I got tired of getting my work slacks getting dirty every time I got in and out of the Jeep trying to step past them.
'97 TJ, 4L engine
I never gave it much thought other than what a PITA it is to keep them looking decent (until I bed lined them). Then a few weeks ago I was trying to get out of my yard in snow and ran over a hunk of log I was using to split firewood. It jammed up under the running board and ended up breaking one end loose. I guess I'll can them pretty soon and hope my 5-2 wife doesn't notice they're gone (fat chance of that). Over the years I may have stepped on them on a couple of times and I can say I won't miss them. My grandkids use them but they're big enough now to climb in without them.
1 - 20 of 22 Posts
