1 - 20 of 32 Posts
Banned
IMO it's too high, especially in back. I'd run flat fenders and drop it as low as possible while still allowing full flex. Low center of gravity rules in my opinion. Nice looking Jeep though
(remember, you asked)
Your opinion is what matters. How do You like it?
For me: I am a "Less is more" kinda guy. I like lower lifts. But, that's just me (probably)
Hate it. My recommendation to you would be to dump that thing in the woods somewhere, say near my house for example, and start from scratch with a new Jeep.
I'm a level guy... Any rake drives me nuts. I would normally suggest a 3/4 spacer in front rather than down in back. But on yours, you have a lot of fender clearance even in front (I like it) and bringing the rear down a little is what I would do. Do you have a spacer you can pull? Or are you thinking a different spring?
My favorite look is a level 4dr 3.5" with 35's and factory fenders... But my favorite overall setup is a level 2dr 2.5" with 35's and flats. :beerdrinking:
With flat fenders it would be defiantly too high. If you wanted to do flat fenders I would go down to the 3"...if I may ask what 3 inch you got? Or thinking about getting if you go down?
Discussion Starter · #13 ·
My options would be to replace the +4.5" springs with +3.0" springs or I do have four 1" front spacers which came with my previous leveling kit that I could add an inch to the front end.. I don't think I want the front any higher - especially with flat fenders about to be installed - so leaving it alone or bringing the rear down 1.5" are really the only options.
What I am thinking about doing to mine is 3.5 inch metalcloak lift, metal cloak flat fenders and 35 inch KO2's. I want it to have more body clearance on the trails...you do not think it would be too much do you? I also have 150-160 pounds on the front, side steps and 100 pounds on the back. Just figured that would weigh it down a bit after it all gets settled.
This is Synergy's Stage 4 4.5" long arm kit.. I'd replace the rear springs with their +3.0" springs.
Oh okay...I didnt know if you had like another lift that you had on there previously. I am looking at the Metal Cloak. I just do not want to have too much of a lift.
Wide stance, excellent tires. From the looks of the pictures may need some additional clearance in the rear as in bumper and maybe sliders. Very nice Synergy lift with res shocks. It should climb like a scalded Gorilla. Great job in my opinion. And if it performs off road as good as it looks I wouldn't change a thing. My opinion for what it worth.
The 3.5 and 35's with flats is one of those that can go either way... Sometimes they look great and others, they look too high and a little out of proportion.
Usually they look just fine, but it's all just an opinion anyways...
Discussion Starter · #20 ·
Put the flats on and then take another side shot. Then you can decide. I like to drive a lower lift vehicle but love the look of 4.5" lifts.
Good advice and likely what is about to happen.. I love this long arm lift but can't get into the rake. Hopefully it won't take long for the shorter springs and bump stops to arrive to test out!
1 - 20 of 32 Posts
