Hello all!
I'm thinking of dropping my tubular nerf bars for a pair of rockers.
The ones i have,i'm very satisfied with, but i'm installing a bl and i'll
have to modify'em a litttle 'cause i don't like the gap that will appear...
They bolt on the frame...
I'm thinking of something like these(totally different approach since they bolt
on the tub...
TJ-30SSR
What do you think?
I would first find someone that can do a good photoshop photo of your Jeep with the new rockers shown on it. As for the rockers themself, I look almost more like a pair of running boards, but if built out of a good thick material, otta get the job done.
The nerf bars that are on your Jeep now look to be pretty beefy. Have you checked under your Jeep as to whether the nerf bars are mounted to the frame or between the body tub and mounts. If it is the later of the two, you could just raise the current bars as you do the body lift and save some cash.
You're right on the photoshop...
The nerf bars are mounted to the frame(bolted on some brackets)
I can easily extend the brackets and call it a day, but i'd like some change...
Thanks for the respond!
I think they will look way too boxy compared to your fender flares.
Good point, the photo with the stock flares are much flatter on the end where the cut out flares are much rounder coming out from the body. Wouldn't fit or look right in my opinion. But yeah, we all know what opinions are like.....
