I just got my jeep shipped up from Ca, and the plastic on the front door skins is completely ruined. I cant seem to find on Smittybilts site, where I can just order the plastic window portion that zips in? I don't need the outer skin or the frame.
Thanks in advance
What's wrong with the plastic windows? A good plastic window cleaner for convertibles will take out some scratches.
The zippered window is part of the upper door skin. Any site that sells jeep soft tops should have the upper door skins.
You might want to check other brands too, Smittybilts reputation is questionable.
Amazon has them for a reasonable price (maybe not Smitty, but other brands).
As mentioned by CHL, you can't buy just the windows - you have to buy the entire soft window assembly that fits over the frame.
I've read where others had a marine shop replace just the windows, so you could look into that if you want to get them repaired.
Don't buy the smittybilt top. I've had one for about a year and I've broken all 5 snaps over the drive side door trying to take the damn thing off.
