1 - 19 of 19 Posts
So the recent jeep I bought has a custom Poison Spyder roll cage, which I'm quite fond of. Also installed are mastercraft seats with 5-point harnesses all around, which I also like.
However, this morning I gave a friend a ride that was a bit heavier-set. She couldn't fit into the 5-point harness, the straps just weren't long enough. I felt absolutely awful. Needless to say, I'm looking to put the original seatbelts back in. I found this little bung sold by Poison Spyder to do just that. However, at $10 per side plus shipping, and the fact that I don't have access to a welder, I'm wondering if it'd be just as safe to drill through the roll cage and just bolt the original seatbelts in. Thoughts?
My idea is to keep the 5-points attached, and bolt both the original belt and the 5-point to the same bolt in the floor bolts.
I thought of this as well... Maybe it's time I learned to weld.
But my original thinking is the strength will be retained if I drill the hole just big enough to fit the bolt, use a lock-washer and don't torque it down too far. Just tight enough to get the lock washer to full compress and hold it there. Hmmm...
Id weld it in or take it somewhere they shouldn't charge much it'll take 2secs and I wouldn't put the 5poimts to the floor it'll mess up your spine they have to have a special bar
Well the 5-points are attached as follows (from driver's side perspective):
Left lap belt (with latch): bolted to original seatbelt reel mechanism bolt (sidewall)
Right lap belt: bolted to original seatbelt latch location (floor)
Submarine belt: bolted through floor to rear of floor pan
Left and right shoulder belts: harnessed to a bar that's welded from one side of the roll cage to the other behind the front seats.
Is this all correct? It seems pretty solid to me.
Ok, I think I'm going to buy the seatbelt bungs and have them welded in. So my second question is do you think it'd be safe enough to double-up the belts onto the original bolt locations? My thought is the stress would be the same on each bolt in the case of an accident, regardless of if it was a single harness bolted in, or two.
Yes the 5 points need yo be mounted with the bar going across the back and when you say double them up im guessing the ones fir the lap belt if so then I don't see why not
Yes, that's just what I mean, the original bolt locations for the original seatbelt are now used by the lap belt for the 5-pt. So I was just going to attach both the lap belt and the original seatbelt into the floor using the same bolt.
I don't know what the PO was thinking with these harnesses. If they have different sizes, I think he got the short ones.
yes, good advice. I'll snap some pics when I get it done. Still gotta order those bungs. Would someone mind getting me the measurements for the stock location of upper seatbelt bolt? I want to know how far it is from the top of the wheel-well, or the floor I guess... Thanks!
Discussion Starter · #12 ·
I got the seatbelt bungs in the mail today. Any chance someone (nudge nicks) could give me a measurement AND a picture (so I can get stock angle)? Pleeeease?
Thanks!
I had the same issue when I bought my YJ I am a big guy, I have been lifting weights all of my adult life. The guy I bought the jeep from was thin and cut the five point harness in both seats to fit him and his wife. I did not want the hassle of a five point harness for the passenger seat for pretty much the reasons you have. My solution was a set of belts from PRP. They make a four point belt that buckles and adjusts like a standard lap and shoulder belt. My wife loves it. PRP will customize the lenght for you.
I forgot I also have a Poison Spyder Roll cage
Discussion Starter · #16 ·
Boy that sounds awesome. Got a link? The only issue is money. I've already got the original seatbelts, so I'm thinking I'll just put them in and maybe look into the PRP belts as a permanent solution to having two sets of seatbelts someday. Thanks for this, I think it will help down the road.
PRPseats.com If you still have trouble PM me with contact info and will have them contact you.
1 - 19 of 19 Posts
