You might even find them at your local auto parts store. At the least, you can try wrapping that cracked connector with tape to see if that gets rid of the code. It takes a day or two to clear once whatever it is that is causing it gets fixed. Or before you start wrapping it, disconnect the battery to reset the code in the computer. Then when you're done and ready to reconnect the battery, that code will be cleared. If the code comes back, that cracked coupler you taped up wasn't the problem.
Oh... so you don't lose your clock & radio station settings, you can instead reset the computer by just disconnecting the PCM's connector closest to the driver's side instead of the battery. Almost forgot about that alternative reset procedure.
