I am preparing for what I may need if I end up with a TJ that has not been lifted, and also if I end up with one that isn't lifted properly. I have searched and investigated and I am still left with a few questions. Here is what I plan to get initially:
~ Zone 4" susp lift (includes transfer case drop from what I understand)
~ MML kit
~ Front and rear adjustable trackbars
~ SYE
~ Quick disconnect sway bar end links (front and rear)
1st question: Am I missing anything crucial right away?
2nd question: Is all of this correct?
3rd question: I have read about a bracket that won't line up in the rear if I use an adjustable track bar and a SYE. Can someone give me some more insight to this and what I would need to do/buy to correct this?
The Zone 4" suspension lift comes with a transfer case drop and fixed lower control arms (which is the case for all economy 4" suspension lifts). The purpose of the t-case drop is to take care of drive line vibrations caused by the steeper angle of the short drive shaft caused by lifting the Jeep 4". The problem with the t-case drops is that you are giving back half your lift height by lowering the center and it is counter productive.
An sye basically allows you to run a longer drive shaft which eliminates the need for the transfer case drop. Along with an sye, you will need a double cardan drive shaft, and at least upper rear adjustable control arms (to adjust your pinion angle). I would highly recommend lower adjustable control arms as well, both in the back and front to help center your axles, and to get id of the fixed arms supplied with the kit. The only adjustable ca's worth buying will either have johnny joints, or Duroflex joints.
There are only three adjustable track bars worth buying, Metalcloak, Currie, or JKS. Metalcloak has the best clearance for the least $'s, I personally am a fan of, and run a Currie in the front. JKS would be my last pick of the three and is generally more $'s. If you use an adjustable track bar in the rear, you generally don't need the relocation bracket.
Another way to go, if you don't want to deal with all that expense, and you want 4" of lift, is the Zone 4.25 combo lift. It's a 3" suspension lift and 1.25" body lift. No t-case drop, no sye. It's a great idea to add a Metalcloak front adjustable track bar, but you don't absolutely have to.
Here's a basic list of what it takes to do a 3.5"-4" suspension lift (YMMV)
3.5”-4”
Springs
Shocks
Bumpstop/extensions
Front Sway bar end links or Anti-rock
Rear Sway bar end links
Rear track bar bracket Adjustable rear track bar - recommended
Front adjustable track bar – recommended, or axle hole re-drilled
Extended brake lines
Minimum of extended lower control arms – adjustable control arms - recommended
Slip yoke eliminator (sye) and double carden drive shaft - recommended, or large transfer case drop
Transfer case shift bracket or Novak shifter if using transfer case drop (not needed with sye)
Parts needed for use with slip yoke eliminator:
Double carden drive shaft
Rear upper adjustable control arms minimum,
Upper and lower rear adjustable control arms - recommended
Angled rear track bar bracket
