Kind of an update from my last post of the blinker not working. I replaced the bulb again and put in a new fuse. All wires are hooked up after being cleaned. Blinker or side light still won't work, but the blinker on the dashboard works perfectly. Not blinking fast or turning off anymore. A steady blink. What else can I look for? Nothing wrong with drivers side.
Thanx in advance
Is it just front or just rear or both front and rear on that side
Also which work and which don't with Hazzard blinkers on
Sent from my SM-S902L using Tapatalk
Both rear lights work with brakes pressed. With the turn signal on, only the front light turns on. With headlights on, neither lights turn on. If this is still confusing I can take a pic.
