The rubber is not sitting flush against door in one spot like it has come unstuck.
It is just happening on the passenger door top left corner (see arrow in photo).
Is this a common problem. Any suggestions for fix. Thanks
Lower the window and see if you can re-seat the weather strip.
If that doesn't work, you have a 2014. This should be a quick dealer fix under warranty.
