water is leaking on my floor mat from the passenger side, any ideas on how to fix this ??
the dealer is going to replace the door seal but i think this is not going to solve it!
2017 JK
I know this is probably not helpful but both of the JK's I've owned and the 2 my buddies own do the same thing whenever it rains heavy.
What I did, was add a strip of NAPA camper Top Sealing tape along the sealing area of the freedom panels. The sealing area is very narrow, and the tape is wider than the area to seal. I apply it, let it sit overnight with the door closed, then trim the excess width with a razor blade. This worked for me. Quiets it down, and almost no leak going through high pressure car wash.
I added it in the red circled area, I would apply some in the orange area as well if your leak is bad, or farther down if need be. Can also be applied to the back if your top has the B-pillar leak.
