PCM was showing O2 sensor error. Mechanic said it was PCM. I ordered a new replacement now jrrp will not start. Power is good but when you turn the key nothing. I put the old PCM back in and same problem. Wires look good on battery. I also beat on the starter. Any help would be greatly appreciated. Thanks
Program PCM
Most Mopar PCM's are NOT plug and play, they will not work just being plugged into the vehicle. It needs to be programmed. A jeep dealer can do it, or find a local company that works on PCM's. Also, there is a learning curve for the PCM in the vehicle.
It is unlikely a new problem with the starter or ignition circuit has arisen since you changed out the PCM.
