That would be a CCV Crank Case Ventilation elbow, no valve, or you have a severely plugged PCV valve, You need to tell us what you are working with....
Back out one page and look for this sticky.
"A better way to get help in the YJ Tech Forum"
If you read through it and let us know what's going on, someone should be able to help you.
There's too many variables to be able to advise you without knowing what you have and what what symptoms you're dealing with.
Good Luck, L.M.
Is there no valve in the elbow?
No, there is no valve... the elbow to the air cleaner is wide open and the one to the manifold has a small orifice
My error once I posted I found there's no edit option on a mobile device. Thanks to all! I have a 93 yj 2.5 through research here I found it is a CCV elbow. I haven't noticed another elbow coming out of valve cover.
Again Thanks to all!
