1 - 1 of 1 Posts
I just installed a set of PIAA 540 Series Plasma Ion Fog Lamps.
I used the switch that is part of the wiring loom that came with the kit.
Is it normal that the lights come on every time the engine is started?
The switch is not a two position switch (on or off).
You have to turn it off each time you start the engine (unless you need them of course)
If this is not normal...any ideas what the problem might be?
:confused:
1 - 1 of 1 Posts
