1 - 12 of 12 Posts
Anyone know what the pinion spline count (NOT the axle count) is on a Sport with the D44 and D30 combo? Northridge shows two options 24 and 26 when looking at new gears and I can't seem to find anything anywhere about the pinion spline count. Axle count is all over the place but that doesn't help :(
Anyone know? I tried to look on Quadratec but they just list gears when you tell it your vehicle and not the spline count on the pinion.
What are you looking at that needs to know ? Link?
Gears on northridge 4x4 when I put my Jeep in as the vehicle it shows both 24 and 26 spline pinions and ring sets for both axles.
Sent from my iPhone 7 Plus using Tapatalk
I put in a 2012 Sport and don't see what you are seeing?
After putting the Jeep in and choosing "drivetrain, ring & pinion" and then setting options for 4.56 and Dana 30 for example I get this listing
https://www.northridge4x4.com/scp/drivetrain/differentials/ring-pinions?filter%5Buniversal%5D=no&filter%5Bspec%5D%5BRatio%5D=4.56&filter%5Bspec%5D%5BAxle+Type%5D=Dana+30
The Ten Factory is one count, the Dana brand is another. Then there's the same problem if I choose the 44. The Yukon and Motive for example right at the start.
https://www.northridge4x4.com/scp/drivetrain/differentials/ring-pinions?filter%5Buniversal%5D=no&filter%5Bspec%5D%5BRatio%5D=4.56&filter%5Bspec%5D%5BAxle+Type%5D=Dana+44&filter%5Bspec%5D%5BLocation%5D=Rear
The JK has 24. The TJ/LG has 26. You need the JK parts.
Thanks yeah it's confusing because northridge showed both for my vehicle and labelled both as JK items in the title
I've noticed that at on a lot of sites. Not sure why they do it.
Yeah it doesn't help that like 99% of the Google searching I did just turned up threads about the axle spline count and the ones that are for the pinion spline count are all people asking but not getting answers.
Vendor
Sorry for just seeing this post. Carlton_Banks is correct. The JK has 24 spline pinions front and rear. I'm going to get with our web team to get those parts corrected to avoid any future confusion!
I apologize for the confusion this caused you, but I'm glad it got brought up and we can get it sorted!
Thanks!
Discussion Starter · #12 ·
Thanks!
Thanks!
1 - 12 of 12 Posts
