on my 12 jku,, teraflex 2.5 coil kit, my pitman arm bushing/boot ( whatever its called) went out after 1500 miles. Is this common? Should i replace it ASAP? And if i do replace it, should i go with a factory part or should i go with an aftermarket bushing. Some say just leave it because it will go bad again anyways. Just want to get everybody's recommendations from here. thanks
Bump
I have the same issue, on mine the boot is torn north to south.
I'm lifted w/35s, is this a warranty thing, or will they deny it?
Will your dealer fix it under warranty? If not i would replace it to keep dirt and water out of the joint. You may be able to find a universal boot at an auto parts store.
