at what piont of susp. lift is it required to get a drop pitman arm? I am a compitant fabricator so im making most of my kit but not sure about the need for a pitman mod. if so I'll buy one, no big deal
Well on a TJ you basically want to move to a drop pitman arm at the point when you have to add a Trac-Bar relocation bracket to your setup. For you YJ guys the steering geometry is a tad different as you don't need the trac-bar. I would say that if you lift your rig and are experiencing a lot of bump steer then you have stretched your steering to it's max and then the addition of a drop pitman arm would help you.
A forum community dedicated to Jeep Wrangler owners and enthusiasts. Come join the discussion about reviews, performance, trail riding, gear, suspension, tires, classifieds, troubleshooting, maintenance, for all JL, JT, JK, TJ, YJ, and CJ models!
