I cant get the pitman arm nut off. i have sprayed p.b. blaster for a week. i have added heat to it and I need some advise. :dance:
X2 its saves your bushing97wrangler-242 said:The nut will be a combination of heat, long breaker bars, hammers, and more pb blaster than you can shake a stick at. When you go to pull the arm off a good trick is to put tension on the puller then hit it with a hammer. Use the strike of the hammer, not the puller to make it slide off
Are you going to re-use it? If not, cut it off with a cutoff wheel on a die grinder.waynowat53 said:I cant get the pitman arm nut off. i have sprayed p.b. blaster for a week. i have added heat to it and I need some advise. :dance:
This would be my advice as well.... Even if you were planning on re-using it, you may consider cutting it off and replacing it just to keep yourself sane.JPi1 said:Are you going to re-use it? If not, cut it off with a cutoff wheel on a die grinder.
Exactlyharleydragon said:cut the nut with a die grinder,cutoff wheel or whatever you have almost to the threads..go to the opposite side ( 180 degrees ) and do the same thing..now take a chisel and hammer and knock the hell out of it in the direction as if you were trying to unscrew it..it will come apart
