1 - 20 of 45 Posts
Folks,
Unless you've been living under a rock, you may have noticed the frequency of passenger footwell leaks we see here. (Like oh, say, this one, or this one, or this one . . . or this one, this one, this one, this one, this one . . . or this one, etc.)
Well, water collects there in mine too. My plan has long been just to pull the carpet and bedline it, but this is a multi-day project I don't have the time to do right. (Like this great job with Monstaliner here.)
So I decided to take a shortcut temporary fix. There is almost ZERO prep involved.
All I did was remove the carpet and drain plugs from the offending area, clean it out with a damp paper towel, dry it out with a dry paper towel, hit it with four coats of spray-on Plasti-Dip, then put down my slush mat.
No sanding the clear coat. No chiseling out the sound deadener. No rollers, brushes, or pump or pressurized sprayers. No primer. Heck, I didn't even tape off anything to avoid overspray. I just used an eraser to rub any oversprayed Plasti-Dip off of the console area, and it came off perfectly. If I don't like it or it starts to look ratty, I can either spray on more to touch it up or just peel it out like rubber (see here on removal).
Total cost: $5. I expect it'll hold up okay until I'm ready to commit to a full on bedlining project. :thumb:
Just thought I'd share.
i'm back
thanks for sharing. man that looks like a fantastic idea on the cheap! let us know how it holds up.. :thumb:
i'm with you, i sure would like to Linex my JK.. but that's super low on the list of things to get done..
-Bob
nice, looks good. I'll be curious to see how it holds up, especially through the winter! i know the plasti dip on my taillight guards is all ready chipping, but it was on chrome so I wasn't expecting much
Discussion Starter · #4 · (Edited)
I'm actually fairly optimistic about it's holding up.
It's inside the jeep and even with the top off it's not likely to get too much of a beating from the sun, so I think that will help. I also don't have front seat passengers too much, but in any event I put back the slush mat figuring that having somebody's heels resting there whenever I do have a passenger wouldn't be good for longevity.
If I get my five bucks worth, I'll be happy! :rofl:
i'm back
Pretty sure you've already got that! It looks good, you're right... the slush mat should help it out with the sun and any abusive passengers. :banghead:
4-legged passengers are in the back anyways! :punk:
-bob
tabber02 said:
Pretty sure you've already got that! It looks good, you're right... the slush mat should help it out wit the sun and any abusive passengers. :banghead:
-bob
And that's a good point--It could surprise me after it cures for a little while, but right now I would not expect this would be very good for anything with claws.
Part of the appeal of Plasti-Dip is that you can get a fingernail under it and peel it off like a rubber sticker. Claws, I would think, would tear it up pretty quickly.
But this is truthfully the first time I've ever used the stuff, so we'll see how it goes. :thumb:
Trail Mom
Husky tub mats, work for me!
When I get a leak, they hold it till I can wipe it up.
Keep the carpet pretty clean too even after I've cut them to fit around my cage.
Discussion Starter · #8 · (Edited)
See, I like the liners too, and was considering going that route. (Indeed, I still may, given that I'm only a whopping $5 bucks into what is an acknowledged temporary fix.) And the Husky's are supposed to be good. Weathertech too. The Q-tec ones seem to be hit-or-miss on whether they warp or not.
Regardless, what's steering me away from the liners is that I'm pretty sure the way the leak comes in would go UNDER any liners I put in. The water appears to be weasling in right over (and perhaps under) the interior door sill guard. See that black plastic to the left of the liner in your pic? The water comes in right along that and decends into the carpet--i.e., I'd expect it'd go right between the liner and the door sill guard.
So I'd still be stuck with wet carpet, meaning the carpet would still have to come out, and I'd still be stuck with a blue interior unless I bedlined/Pasti-Dipped/whatever it. :(
Same leak issue here, I took the long weekend of prep and bit the dust to have it Line-X'd. Well worth it.
No doubt, that's the plan eventually. Though I'll have to decide between doing it DIY or getting it professionally sprayed. If you don't mind me asking, how much did getting it Line-Xed cost given that you did much of the prep?
With me doing all the prep, the guys in Burlington did the base liner for $600 and I upgraded to the premium for an additional $100. The premium gives it a little gloss and UV protection.
Discussion Starter · #13 ·
These guys? That's only about 40 minutes from my house . . . . And of course, the good DIY kits run close to $300 . . . .
Really pleased with those guys. I work in Asheboro and dropped it off in the morning..picked it up,that afternoon. Really careful and detailed work.
Discussion Starter · #15 ·
Prep pics...
I need to get some after pics.
Please do get some after pics. Is that bondo or something I see in the corners there? What was the thinking with that?
Pics later today. I pulled the ugly seam goop out along with the sound material...that is just primer you see because I got down to bare metal in a few places.
Didn't even realize we had another Line-X person in Burlington besides Lakeside Campers on Webb Ave. Think they are called Leonard now or something. Is the place you used the same place that does JetHot coating and stuff, out off the highway near the Whitesett area?
On edit: Nevermind. Looks like its the same place. Wonder what they would charge to Line-X my grill. hhmm...
Discussion Starter · #18 ·
Is that safe? What is the purpose of the seam goop? I would've assumed it was holding the seams, ya know, TOGETHER. :confused:
I'd like to do my grill also. I might do that as a DIY project.
1 - 20 of 45 Posts
