Afternoon folks,
I have had upper/lower ball joints, uper/lower control arms, new cam bolts, front heavy duty steering stabilizer, tie rod end, track bar, and new springs and shocks put on my 2004 Jeep TJ Rubicon (114,000 miles, 5 speed).
This solved the death wobble for 3,000+ miles. I was in TX for the summer and when I hit the NY border the wobble came back. The bolt on the track mounting bolt was found to be loose.... death wobble happened again after it was tightened.
My mechanic is out of ideas other then a steering gear box (there is grinding and play in it) or wheel bearings (but tests seem to show that they are ok).
The Jeep has 2.5" skyjacker springs with 2.5" rated quadratec shocks in front. And a .75" quadratec puck lift in the rear.
Wobble comes about at highway speeds and is very violent.
I am sorry if this is a old thread. I've done alot of research and cant figure out what's wrong with my jeep. I hope someone can help. I saved throughout HS for four years for it and it means alot to me. I am a college student on a budget and hope this can be resolved.
Thank you so very much.
