I have a 94 just the other day while driving my jeep all of a sudden sounded like it had an exhaust leak, I also noticed under the dash by the steering column I could feel air coming in. Has anyone have this problem before?
Going to have to get underneath while it is running to find the leak. Could be anywhere from the exhaust manifold to the tailpipe.
Air coming from under the dash indicates an uncovered hole in the firewall. Open the hood and look at the firewall. Everything coming from inside the cab should have a seal. The one around the speedo cable is a player but check closely. If you have an unused hike in the firewall patch it up you can RTV a washer and fill the center with more RTV.
