I had break lights and now i dont
i looked at my fuse box and it seems all mixed up
the fuse that says ign/lps is my back up light and the one that says haz stop has nothing in it. im not sure there is one fuse blown and its the cruse/ back up or something but when i put a new one in it nothign different happened.
i think it might have something to do with my system that is hooked up to it but i cant seem to pin point the problem
i have a 92 yj 4cyl
please help me i cant be rollin around w/o break lights thats a fat ticket:(
Administrator
I will assume you checked the bulbs? Check the connector next, they have a way of working out over time, also check your ground wire. Also check under the dash at the peddle itself as I think it works off a contact as well to turn them on and off.
yea i changed the bulbs and switch at the break. also i checked the fuses.
how do i check the other stuff
also my jeep wont start sometimes unless i tap the break a couple times idk whats up with is it just seams like the break system if messed up
Administrator
You will need to get volt tester and start at one end and work your way around, I am thinking its a bad ground someplace, perhaps a while you can't see. As for the brake to start not sure on that.
