Hello,
I have a 04 Rubicon and i just recently installed a 4inch lift onto it. I have the stock tire and rims. I now want to put 33inch tires on my stock rims. Is this something i can do? I am getting mixed answers. Someone told me i need a bigger rim with an offset? Is this true? Please help
thanks
ruby
Jeeper
You have to use spacers/adapters to fit 33x12.5's on stock wheels. If you are putting 33x10.5's on you should be fine, tho depending how wide they actually are you may need to adjust the steering stops with a couple of washers. Tire width and wheel backspace are the important factors here...
Administrator
do you have 15 or 16" rims? If 16, you might be able to fit 285/75/16's on the stockers.
