Hi guys. I just bought some rims and tires at a great price but jam concerned about the proper fit. I think I def need a lift just not sure how much of a lift. The rims are 22in by 10 with a -25 offset. and tires are 35 12.50\22 these things are huge. I only do street driving no off road. I read about other factors like braking and re gearing did I make a big mistake getting these ?? Any input would be great. Thanks
Not sure about that offset? You will need a 2.5" lift for sure with 35"s though. Did they come off a jeep wrangler?
10" width, -25 offset = 4.5 backspacing. Your good.
A 2.5 lift budget boost will suffice based in your needs. If you plan on adding weight, get coils.
Bigger brakes - you can do that later
regearing depends on what jeep you have. do you have the 3.8 or the 3.6? auto ro manual?
the general rule of thumb is
3.8 auto - 4.88 or 5.13 gears
3.8 manual - 4.56 or 4.88
3.6 auto - 4.10 or 4.56
3.6 manual - 4.56
you are gonna need atleast a 2.5" lift to fit those 35s without rubbing.
Leveling kit and your good, for mall crawling. Cheap and easy to do. And I'm guessing with that wheel/tire combo you were going for looks and not off-roading. Not sure your gear ratio, mileage will take a hit regardless, but if you have higher then 3.73(lower numerical) then it will be a dog.
