1 - 1 of 1 Posts
Hi. On my 2008 JK it developed a squeaking type noise in the right rear. And it got worse on left turns. I read some and thought for sure it was the rear axle bearing. We replaced the bearing and seal. The noise went away for a few days and came right back EXACTLY the same. It's like something we touched changed it for a little while and it came back. We did notice in the middle of the rear end looking through the axle tube something is out of position. Maybe a shim. Any thoughts on what this squeaking noise could be? And when you turn left loading that side it gets worse. It sounds like metal on metal something. Brake pads and emergency brake pads have both been replaced. See photos. Thanks for any help!
1 - 1 of 1 Posts
