Hey all sorry this is my first post but everything else I had problems with i was able to search and find the answer. I have a plug which looks like a computer plug under my dash by the driver door. Also I have a red wire that was electrical taped to the wiring harness by the previous owner spliced into. I unhooked the wire and everything is still working fine any ideas?
Obd ?
My opinion is that red wire is a Hot lead either off the battery or the fuse box. A few tj models, including mine, a 2000, have 2 hot leads off of the fuse box behind the glove for accessories. There is a red, which is always on, and a blue, which works off key in pos 2. Trace that red wire to see if its live, was most likely hot for a cb, fog light switch or something. The little computer port is for the mechanic scanner for the codes if i'm not mistaken.
3 prong fog light switches need a hot 12v lead to light up
