So I had my inspection done today and tried to clear the code before but it didn't work. They did a leak test and found it to be a cracked fitting on top of gas tank and quoted me $1,080 to replace it. Anyone have any experience with it? Thanks
Retired Moderator
Ouch. I had that code and it was just that when they installed my evap skid they didn't tighten one of the connections enough. Tightened it up, code gone.
I had that same code about a year ago.... Researched the problem and found the problem to be the gas cap was not sealing properly. I removed the gas cap, wiped down the seating surface on the filler neck with a rag and throttle body cleaner. Inspected the gas cap O ring and wiped it down with a rag dampened with water. Applied a thin film of grease on the neck sealing surface and reinstalled the cap. Drove around for about 30 minutes and the code cleared.
