1 - 1 of 1 Posts
Just installed the 24 LED 4in tail lights, but i've been struggling to wire them up correctly. Every diagram I can find has different color wires then I have in my 06 tj. Upon wiring them up I can get the tail lights and brake lights to work correctly but the left turn signal won't work at all, and when I use the right turn signal both tails lights will flash. I also purchased the poison spyder LED flasher but upon installation I found out it was defective and had to pick another one at auto zone. I have played around with all the wire connections and these are the only ones that get the running and brake lights to work. Any ideas are much appreciated.
1 - 1 of 1 Posts
