1 - 20 of 30 Posts
So hear I am going 70 down the highway, stepped on the gas to pass someone. looked at the rpm gauge and it was a 0. my truck stalled and almost went into the guard rail. coasted down the shoulder once I hit 30 my truck then restarted by itself and back fired a couple times. I couldn't help but laugh at what was going on:rofl: one It stopped I let it sit then it started back up and made it home fine. any ideas to what it is?
You're parents must have put a 70 MPH governor on it so you don't hurt yourself. Unit makes you come to a complete stop to give you time to come to your senses. They just care
HAHA! They were in the passenger and back seat. My mom said "oh here we go again" it was in jersey too. I had to go fast it was drizzeling and I had no top on. My jeep only drives nice on the high way. and I will put some seat covers on the list along with some pampers cruisers
blinker fluid is over filled
Discussion Starter · #14 ·
NO way! I just put in royal purple blinker Fluid!. Hmm I just gutted my cat the bearings did look ok though. I think my Carburetor crankshaft is bad. has a slight wobble. I tried starting up my truck at night and seen some arching and I think I might have an intake leak.
Possibly a flux capacitor. Did you change your fluid yourself? Did you do it at operating temp? Both sides equal? It's a tricky process and can ruin your jeep.
Retired Moderator
spray some brake clean around the manifold... it should stall right away if you have an intake leak... :thumb: or it could be the previously mentioned flux capacitor. if you're not getting the right voltage from lightning strikes.. that can happen.. :whistling:
What about the air color in the tires? Purple is for slow, Red is medium speed and then there's PLAID for the super fast speeds...
Retired Moderator
yeah I did. It's really a time machine now. Not sure, the wonderful people at pepboys changed it for me. I have always had my fluid changed every 100,000 blinks.
If its a time machine... Simply go back in time BEFORE the problem started and everything should be fine! :thumb:
1 - 20 of 30 Posts
