My 4.2L w/ a MC2150 and nutter bypass feels like its not getting enough gas when I try to accelerate. I switched out the fuel filter and checked the pressure from the fuel pump. It just recently started this so I am a bit lost. I think the carb may have fallen out of tune but it idles smooth as a prom queens thigh. Looking for any advice from the great YJ council.
I ran a 2150 on my 4.2L for awhile, and it "fell" out of adjustment constantly. The MC2150 is a good carburetor, but it is tempermental when it comes to climate changes, altitudes, moisture, and the like.
I had the same problem that you are experiencing last fall when the weather changed in the fall, the cooler air caused it to have a starved for fuel feeling.
You can try advancing your timing a touch, and tuning the carb with a vacuum gauge, that seemed to be the best for me, but as soon as the weather changes again, so will the carb.
The weather in the SoCal area is starting get cooler, usually in the 40's in the morn and then 70's in the afternoon. Thanks for the help. I will try advancing the timing a bit and then tuning the carb a bit.
Before this week it never had that problem. I took it to a carb guy in town because I could not get it to idle smooth when it was cold. Now it idles smooth but the hesitation is there. Tomorrow I am going to try the timing, its already set at 8 BTDC and see how it goes. If that doesnt work I am going to start doing some adjustments myself. I just dont want to get back to where the idle is rough.
