As you can see I'm a noob to the forum and Wranglers, need some help. Just picked up an old 93, it's got the low type Soft Top doors, but a hard top. Are there Pop in or any Windows that work in this combination? And if so where should I look. :confused:
Thanks in advance for any help.
JV
Edit: came across these?
http://cgi.ebay.com/ebaymotors/JEEP-HALF-SOFT-DOORS-1992-JEEP-WRANGLER-PAIR_W0QQcmdZViewItemQQ_trkparmsZ72Q3a543Q7c39Q3a1Q7c66Q3a2Q7c65Q3a12Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem170269750451QQitemZ170269750451#ebayphotohosting
Im confused. Are you saying that you have hard lower doors, soft upper doors, and a hard top? And the soft uppers you have dont fit with the hard top? If so, then yes, those round upper doors should work with the hard top.
To Clarify I have the Hard low cut Lower doors,no roll up window. A Hard top. I'm new to the block so I may not have the terminology right. I want to get those windows if they'l fit
I think it's still pretty muddy as to what you are looking for. With the half doors and soft uppers, there are manufacturers out there offering the soft uppers with hard sliding windows. Possibly the Bestop Part Number 51786 http://www.bestop.com/index.php?s=19
Is this what you're looking for?
I appears those windows you linked me to go with soft tops, the doors in the pics are the same low ones I have. This vehicle was originally a Soft top then the guy put on a hardtop. I don't have the soft top. My question is will the pop In windows that I found work on those low doors and be compatible with the Hardtop, I don't care if there sliders or zippers. will they fit?
yes there are two types of upper half doors. round or square. if you have the hard top, which has a round door frame, then the round upper doors will fit, like the ones in your photo. some soft tops have square uppers, while some have round. if you get the round ones that you are looking at then they will fit on the hard top. it will look weird, but they will fit. the windows are not pop in, the upper doors have three poles that fit into three holes on the hard lower door.
Discussion Starter #7
Thank you Red....yes I was aware of the poles n' holes....just didn't have the right terminology.
