1 - 15 of 15 Posts
Hey all. About 3 months ago I picked up a 2011 Wrangler unlimited JK after many years being "away" from the Jeep family.
Since getting my Jeep (and BEFORE lifting it 4") I continue to hear a popping or rattling sound coming from my B pillar - inside where the seatbelt mechanism lives. Has anyone else experienced this sound or know what I'm referring to? I've pretty much dis-assembled the whole seatbelt/B-pillar coverings and still can't find the source. Arrggggh.
Thanks!
I recently purchased a 2009 Unlimited Sahara and had the same problem. I read somewhere that the sound comes from the door latch. I put some electrical tape around latch catch and problem solved.
Our 2012 Unlimited Sahara makes popping noises when we first drive it, coming from various places, at first I thought something was loose, now I'm thinking the rubber between hardtop and various body parts is just shifting due to temp differences, sort of like a "plate shift" earthquake. I don't hear a rattle, as much as just a few pops, a few minutes apart.
just put enough so the door stills closes properly, too much and you will have to slam door shut. I think I put 3 or 4 wraps around.
Couple wraps worked for me. :thumb:
Popping Sound
I used the tape on the door latch and it has stopped the popping sound, Thanks for the information it works.:dance:
Wow - such a technological fix! I wonder if Jeep knows about this problem. I'll give it a shot. thanks all.
I have had my 2011 Wrangler to the dealer 3 times for this. They are getting frustrated as well as me. This is a awesome tip! Going to try it right now......
B Pillar rattle
Was having this issue and did some research. In my case I thought the noise was coming from the pillar it was actually coming from the hard top. Remove the freedom panel and check if the bolt above the pillar is tight.
Hope this helps!
Been an issue since 2008, hit a but and there it is. But put some miles on it, the rest of the Jeep will end up doing the same, and pretty sonn, you won't notice it anymore :blackeye
I had a popping noise that sounded like it was coming from the b-pillar also. After tightening everything I could find, it didn't fix it. So one day I decided to tighten all the torx bolts around the cowl. I'll be damned if that didn't fix it. The ones that made the difference are the ones at the lower part of the cowl, not the a-pillar (where everybody gets the door ding). Wouldn't hurt to just give them a once over and see if that fixes it.
if it sounds stupid but works, it isn't stupid :D
Hard top? Pop off the freedom panels and tighten it down. That solved a popping issue I had recently.
Thanks!
I know this is an old thread, but I am having the exact same popping/rattling noise you are describing. It is coming from the same area as well, definitely not coming from the door latch. I did the tape trick just to be safe.
Did you ever discover a fix?
1 - 15 of 15 Posts
