I’m sure this has been posted before but I either suck at searching or I’m missing it. I am about to start the 3 part process of using POR 15 on the undercarriage. Which exact parts should be avoided, if any, while using the product? I did read some parts should be only coated once. But couldn’t find much more. If someone could break down parts to avoid and which can handle a single coat. 🤟🏼
I did not do POR 15 put I had Line-X undercoat my JKU, they told me everything that doesn't 'turn or burn' gets coated, i.e. axles and exhaust system.
I coated everything on mine besides the ones with plastic and rubber, and the exhaust pipe. The shafts u-joints, shocks, tubing and coil springs were all painted with no mercy.
